Exhaust Size For My Setup
Old Jul 11, 2004 | 01:13 PM
mikecl713's Avatar
Default Exhaust Size For My Setup
my setup.. comptech sc with toda cams.
will putting a 3" exhaust be beneficial with the extra flow or is it overkill...
or will a 2.5" be more efficient..
Old Jul 11, 2004 | 01:40 PM
Dolemike's Avatar
Id say 3", thats just my guess as I know FI's like the extra flow. Im sure theres someone on here that can give more specifics.
Old Jul 11, 2004 | 03:52 PM
Mr. Francesco's Avatar
i think you want a 2.5. the supercharger runs of the motor, so back pressure is required. if you had a turbo setup, then you should go with a 3''. im pretty sure that i will be buying a comptech sc, and i just purchased the dual r1 amuse, the piping is not 2.5 all the way through, it varies between 2.25-2.5. what ever way i will be going, ill be running the same setup i have. 2.5 is fine for low boost applications.
Old Jul 11, 2004 | 10:51 PM
mikecl713's Avatar
but will having the toda cams gonna need for a bigger piping due to the bigger breaths the engine takes?
Old Jul 11, 2004 | 10:53 PM
i can't help you with that one. best advice i can give is to call toda up and ask them. but for a supercharger setup, id stick with a 2.5...
Old Jul 11, 2004 | 11:37 PM
mikecl713's Avatar
i did and they have no data on it....
since they only make parts for NA
Old Jul 12, 2004 | 06:57 AM
derryck's Avatar
You only need a 3" exhaust for a turbo set up...2.5" should be fine with SC.
Amer
Nov 21, 2007 02:07 PM
S2Kabob
Oct 14, 2006 06:19 PM
2k1wolfster
Apr 19, 2005 08:25 PM
Mr. Francesco
Jan 31, 2005 11:21 PM
Dj K-otik
Mar 4, 2003 05:46 PM
