Express Window Down is BUSTED @ Only 3000 Miles!
Originally posted by RT
combo job, do A) until a confirmed "fixed" part exists then roll the dice for part B)
WACKY UPDATE WACKY UPDATE WACKY UPDATE WACKY UPDATE WACKY UPDATE
You guys are not going to beleive this. I decided to tough it out and let sleepy dogs lay. i.e. not get this fixed.
Without having done a single thing differently, my express window down came back to life gradually. Now it really works 100% of the time. How weird is that?
had my regulator replaced last spring, and it hasn't happened since. no door rattle. door panel was also off to place dynamat in door when the speakers were changed out...still no rattle...so i wouldn't worry about that.
it just became so damn frustrating that i had to have it fixed...don't worry you'll get there...
good luck.
good luck.
I have an '02 that had the same symptoms about 10 times in a couple days (at about 2000 miles), then it started working again. I don't know what the deal was, but it has worked fine ever since, and I now have 7600 miles.
Mine has been busted forever but I thought it was something I did when I ran speaker wire through that wire loom. Guess not... Interesting observation though... If the window is in the up position, ie closed, it NEVER goes express down. If I roll the window down and then back to the up closed position, then the express down will start working again, but not for long... Wonder why huh? I just attribute that to the personality of the car...
Chris
Chris
yeah, mine doesn't work either, and i've thought about replacing the switch under it's warranty, but i dunno.....i got two fingers, and i have hold the other switch to get the passengers window down anyway, so i doubt i'm gonna get it replaced. Esp after seeing people on thier 8th and farther switches. damn.
