exterior door handle removal
Old Aug 13, 2006 | 05:58 PM
Falkien's Avatar
Default exterior door handle removal
I have an 02 s2000 and I am trying to remonve the exterior drivers side door handle. I have gotten the 2 10mm bolts off but it looks like the loking mechanism is stopping the handle from coming out. If anybody has sucessfully removed one please help...matt
Old Aug 13, 2006 | 07:38 PM
Avionics86's Avatar
First you need to remove the other end of the thick rod-one end at the door handle and the other end is at the door latch-held on with a 10mm nut. Then remove the key lock that is held on by a u shaped spring clip. Once you have removed the clip you can push the key lock assembly inward and slide the brackit off (the one that was held on by the two bolts). Then from the out side of the car pull out the handle and unscrew it from the rod-put a piece of tape on the rod threads before unscrewing it makes it easier for reassembly-used as a guide. Do not force anything- if all the correct parts were removed the door assembly will slide out.
Good luck
Old Aug 14, 2006 | 06:02 AM
Falkien's Avatar
Thank you for the quick response, I will try that tonight...matt
kaansahbaz
May 26, 2015 10:57 AM
peters2000
Nov 9, 2009 01:26 AM
fishyirl
Feb 16, 2009 12:41 PM
StreetLegalGoKart
Mar 28, 2008 10:32 AM
nearwater4me
Apr 5, 2007 04:37 PM
