Extreme oil consume, 5 liter every 7500km
Old 02-01-2019, 07:51 AM
  #31
Filigranas's Avatar
Hello again,
Does anybody knows how many hours of handwork has the replacement of the valve retainers stuff?
Being told 5, others say from 15 to 20 hours etc.
Thanks
Old 02-01-2019, 01:08 PM
  #32
nubbel's Avatar
Can't comment on the time needed but you could shoot a message to Jason (DIYGuys on YouTube) he has made a great video on replacing the retainers (https://goo.gl/ZsVfyM) and has done it on a few motors in the past.
I know he has an account on this forum but I can't remember his username unfortunately
On a side note, make sure NOT to reuse the old retainer keepers AP2 retainers use their own keepers!
Filigranas (02-01-2019)
Old 02-01-2019, 01:46 PM
  #33
Deckoz's Avatar
It took me about 8 hours total to replace the retainers/keepers & valve seals, taking a break for food before putting the rocker assembly back and adjusting lash. Working at a slow methodic pace with a beer or three along the way.
Old 02-04-2019, 03:32 PM
  #34
Filigranas's Avatar
I have been told that after replacing all the valve retainers etc, some part of the engine must be rectified.
Do not know if is the exact English word, rectify is when on an old engine you put new piston and the old cilinder must be polished ,something like that.
Can any who replaced my wrong stuff did this?
My dumb logic says they only need to be replaced.
thanks
Old 02-04-2019, 04:11 PM
  #35
Deckoz's Avatar
thanks
Hi
The job doesn't require any machining. I would suggest doing valve seals while you have the parts removed, if your mileage is high. The only post replacement work needed is a valve lash adjustment, once the cams and rockers are reinstalled in correct time.
Filigranas (02-04-2019)
Old 02-04-2019, 04:36 PM
  #36
Filigranas's Avatar
Originally Posted by Deckoz
Hi
You mean the valve adjust that is needed every, from memory was like 40-60.000 kms. right? Anyway if you mean that, it has to be done I have been told.
Do not know why I have been told to do the machinery thing... I got 145.000 kms. 2001 model
what is valve seal btw? sorry my knowledge is low as it looks.
Old 02-04-2019, 05:22 PM
  #37
Deckoz's Avatar
yes like the valve adjustment for every 40-60km, once you replace the retainers and keepers, and reassemble, it must be done before running the engine.
Valve seals - they are the seal that seals oil into the head around each one of the valve stems, so that oil does not leak down the valve guides into the intake and exhaust ports. When you remove the retainers and keepers, they are at the base of the valve spring cavity where the valve stem protrudes from the head.
Old 02-04-2019, 09:55 PM
  #38
flanders's Avatar
Valve seal 12210-PZ1-004
Old 02-04-2019, 10:35 PM
  #39
Deckoz's Avatar
^^^ just as a side note, exhaust and intake are different part numbers if anyone does both sides when doing retainers
Old 02-05-2019, 09:17 AM
  #40
Filigranas's Avatar
thanks!
will do both
Hi
I will,
btw, a friend who worked on Honda Europe just told me the exact word:
cylinder head resurfacing, I mean, are you all sure I do not need to do that machinery polishing after replacing all my stuff?
thanks
Quick Reply: Extreme oil consume, 5 liter every 7500km
