F20 into AE86 - couple questions
Old Jun 30, 2013 | 08:16 AM
EGRacing's Avatar
Default F20 into AE86 - couple questions
Hi people! I'm in the middle of a F20C conversion into my AE86.
Here's a pic if you want
However I have a couple questions...
Since I'm using the original AE tank, can I just T-joint the fuel purge tube into the return hose that goes from the fuel pressure regualator and to the tank?
I have no purge tank / system.
I also have 2 vacuum hoses on the front of the engine that are just cut, and I have no idea what they are supposed to go to.
What are they for and can I just loop them?
Any help appreciated
Old Jun 30, 2013 | 02:05 PM
chris_barry's Avatar
Yes and yes.
Old Jul 1, 2013 | 07:13 AM
jl56tc's Avatar
it still runs if you delete them....just follow the lines and remove all the ones that dont connnect to anything
Old Jul 2, 2013 | 01:03 PM
s2klariat's Avatar
The two vacuum hoses go to the secondary air injection system. Purely emissions related. Are yoy going to use a f20 ecu? If so you'll have check engine light. Won't effect performance though. Check into izzy's delete kit if it bothers you.
Old Jul 3, 2013 | 11:41 AM
EGRacing's Avatar
Ok thanks for the answers.
I have another question about the conversion.
I have a JDM engine with JDM ECU, does the fuel pump pin from the ECU give 12v, 5v or does is ground the circuit?
s2000sccaracer
Aug 21, 2012 03:15 PM
Jwslick
Jul 12, 2008 11:46 PM
millertown15
May 8, 2006 06:20 AM
kayvan_pour
Feb 23, 2006 01:18 PM
mrhut
Aug 27, 2001 04:32 PM
