F20C increased redline
Old Apr 16, 2008 | 11:15 AM
ZCP M3's Avatar
Default F20C increased redline
Hey all,
I'm considering a Stack gauge cluster for my F20C Lotus 7 project and I'm trying to plan ahead. I don't see myself going FI on this car, so if i want more power it will be by spinning the motor to god-awful heights. How much can the stock bottom end take with cams that can support the upgraded flow? The tach Im looking at is a 0-3-10,500rpm model. Can they spin any higher than that without serious $$$ dumped into them?
Old Apr 16, 2008 | 11:37 AM
LostMotion's Avatar
Old Apr 16, 2008 | 12:02 PM
MULDER's Avatar
Whats the point? Power (both torque and HP) drops off significantly right after thier peaks and before redline. I cannot see how spinning it higher will not get you anymore power from this engine.
Old Apr 16, 2008 | 12:03 PM
c_me_go's Avatar
unless under boost...
Old Apr 16, 2008 | 01:15 PM
ZCP M3's Avatar
I'm talking about a stock bottom end with cams and ITBs. There isn't any power to be had from that?
Old Apr 16, 2008 | 01:56 PM
3ngin33r1's Avatar
Isn't 10,200 float point?
Old Apr 16, 2008 | 02:04 PM
BlownAP's Avatar
you can make power all the way past 9k. you will need the PROPER cams, at this point the only cams I have seen make power are the Hytech. Long wait and expensive but worth the money.
BlownAP's Avatar
[QUOTE=MULDER,Apr 16 2008, 01:02 PM] Whats the point?
Old Apr 16, 2008 | 02:11 PM
ZCP M3's Avatar
Okay. Assuming I have the correct cams, a good tune, and the supporting mods (ITBs, stiffer valve springs, etc etc), what can the STOCK BOTTOM END safely spin to? 9500? 10k? 10.5k?
Old Apr 16, 2008 | 02:12 PM
3ngin33r1's Avatar
Safely, most likely OEM specs for redline. But if you're doing all this work to it, why is safety a concern?
