f22 block with f20 head?
Old Aug 8, 2006 | 10:27 AM
94h23vtec's Avatar
Default f22 block with f20 head?
hi i'm a brand new member at s2ki, i dont have an s2k but im intrested in purchasing one, i own an h23vtec prelude and i have the following q's about the s2k.
i did a lil research on this but didnt have any luck trying to find out if any one has f20 head on an f22 block? i dont know much about s2k motors and im not sure if there is even a difference in the ap1 and ap2 heads. i was interested in building a motor like this cuz i think that would be a good setup for all motor, cuz i dont see that there is that much benefit in allmotor aftermarket parts for the s2k.
this is the setup i think should get a good hp/tq #
f20 stock head
f22 block (balanced/blueprinted/knife edged crank, not sure what pistons to use ithink jdm f20c pistons for a lil higher compression)
stock i/h/e
some sort of fuel manegment not sure which one yet
what do you guys think?
sorry if there is any stupid q's or comments im a newbie to s2ks
Old Aug 8, 2006 | 11:10 AM
OGPackin's Avatar
The heads are interchangeable....Im running an AP2 head on an AP1 block......My car loves the setup... Good luck!
Old Aug 8, 2006 | 11:11 AM
94h23vtec's Avatar
hello anyone
Old Aug 8, 2006 | 11:17 AM
GPS2K01's Avatar
What kind of benefits are you experiencing with the AP2 head...you N/A?
Old Aug 8, 2006 | 11:32 AM
OGPackin's Avatar
FI......A local I bought the head from had a similar setup as me. The only real difference he was running an AP2/AP2 setup. We made around the same rwhp, but I made it running 4psi boost less then he was. My mechanic attributes that to the block/head combo.
Old Aug 8, 2006 | 12:02 PM
Dark's Avatar
FWIW, the ap2 head has stonger retainers.
Old Aug 8, 2006 | 12:42 PM
CrazyPhuD's Avatar
There are many things that can contribute to power. The AP1/AP2 bare head is identical. What is different between the two is the cams. It is said that the AP2 cams are better for FI and the AP1 cams are better for NA(AP2 has less overlap if I recall). However the magnitude of the difference hasn't been measured.
For your case since you're both running AP2 cams you'd gain ~10% from redline benefit but the 2.2L would gain ~10% from greater displacement, which would be a roughly a wash. The block head combo had little impact here. The reason your system is more efficient is in the turbo design/tune.
Old Aug 8, 2006 | 12:54 PM
OGPackin's Avatar
[QUOTE=CrazyPhuD,Aug 8 2006, 03:42 PM] There are many things that can contribute to power.
Old Aug 8, 2006 | 01:24 PM
94h23vtec's Avatar
so how much power do you guys think this setup would make
Old Aug 8, 2006 | 06:09 PM
s2kBryan916's Avatar
If you search you will find many treads on this topic.
Silverstone_turbo
Sep 28, 2017 10:47 AM
BoostMeUpScottyS2k
Nov 21, 2015 11:51 AM
Mr. Francesco
Jun 2, 2008 02:33 AM
BMACMAC
Jan 22, 2007 07:55 PM
beautyofS2K
Oct 11, 2006 06:49 PM
