F22 head question
Old Nov 3, 2012 | 09:50 AM
Clark's Avatar
Default F22 head question
Hey, I've got a head for an F22 I bought a few years ago. I don't know what year it is. The head has the casting channel on the exhaust side for the air pump/egr system, however it isn't drilled through to the other side for the air pump on the intake. It is also missing the two studs to mount the steel cover.
Did they stop doing this at some point and just leave the channel in the casting?
Will I be able to use my 2005 intake manifold (which has the air pump, though blocked off) on this head?
Or preferably, will I be able to use my 2001 intake manifold on this head?
Thanks.
Old Nov 4, 2012 | 08:53 AM
afzan's Avatar
04-05 has air pump
06+ doesn't have an air pump
I can't remember the specifics but the head is slightly different between the two, one of the differences being the air pump casting, valve cover is different, tdc wheel/sensor, PCV and more. These are all the same 06+ parts required to use a kpro on a 00-05 car
Since you won't be able to run the airpump you'll need some sort of EMS or air pump delete circuitry from izze (unless you don't mind the CEL to be on)
Old Nov 4, 2012 | 05:37 PM
Clark's Avatar
not worried about CEL light yet. Just want to make sure my hardware will work:
'01 intake manifold and fuel rail.
Looks like I might need a new valve cover? Or modify my '01 or '05
The TDC wheel sensor? Is this the crank position sensor or the cam position sensors you're talking about?
PVC stuff all easy to deal with.
Thanks.
dsthez
Oct 19, 2016 10:25 PM
starrman
Dec 9, 2013 07:42 PM
Sideways
Mar 14, 2010 07:50 PM
lotus7racer
Sep 22, 2008 10:31 AM
v-tec maz
Oct 5, 2007 08:09 PM
