F22 swap
Old Mar 19, 2009 | 10:55 AM
Monsterofacar's Avatar
Default F22 swap
Hey just wondering if anyone can point me to the right direction. I need maybe a website or a thread with the whole process of swapping a f22 onto a ap1.
Something other than helm.
I already tried searching on here but nothing comes up. I know it's fairly easy but just wanted to read up on it.
-btw 2005 motor onto a 2002.
Thanks
Old Mar 19, 2009 | 12:00 PM
LostMotion's Avatar
There are no difference between the motor other than the crank and the pistons, so it's just like any engine swap. I don't know of an engine swap DIY on here. Obviously the service manual (which is very cheap for the older years) would pretty much cover you.
Old Mar 19, 2009 | 12:32 PM
SC_Highlander's Avatar
Read the helm manual for engine removal and installation. Remove the F20, then Install the F22. The only non-standard thing I had to do was remove a metal tab on the fuel rail. The new motors have a set of tabs to locate the fuel feed line and keep it from twisting. The fuel feed line on the older cars will not fit between the tabs, so I cut one of the tabs off. Other than that, it's a direct swap and all procedures in the helm manual are 100% accurate. All bolts and wire harnesses/sensors are in the same spots.
Runninlo
Feb 1, 2015 03:12 PM
Judgee
Jan 29, 2015 08:40 AM
jaydiii
Jun 3, 2014 11:02 AM
slamar1
Jul 14, 2005 04:23 AM
lexar13
May 12, 2005 05:52 AM
