f22c swap into 01' AP1
Old Oct 22, 2011 | 08:39 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
A 2004-2005 engine can be put into any ap1 in any configuration. Short block, or fulled loaded long block with every sensor, intake, and wiring harness. It is a direct plug and play, the 2004-2005 harness will plug right into the AP1 ecu. With that said, of course you may retail your original AP1 harness and any parts the AP2 engine may be missing.
The ONLY physical mod will be to cut a small tab off the fuel line by the rail, if you use an AP2 fuel rail with an AP1 fuel line. And that is IT.
I would recommend keeping the AP1 flywheel as well.
Old Oct 22, 2011 | 01:08 PM
TerminatioN's Avatar
Yep. I kept my AP1 flywheel when I put in the MY05 f22c engine. Perfect combo with the AP1 trans.
Even better with boost.
Old Oct 22, 2011 | 02:27 PM
Billman250's Avatar
Top Answer: 1
bigger question...how would the 2.2L engine perform with the AP1 camshafts designed for 9k rpm.
Old Oct 22, 2011 | 09:28 PM
thielepr's Avatar
umm, that a very interisting question. I don't want my engine to blow never but if eventaully it does, a f22c will be on my AP1. I always have the concern about the 8,900rpm in the F22c. But the AP1 camshafts?? it's a interisting question
Old Oct 23, 2011 | 05:34 AM
JUSTINTHECOASTIE's Avatar
I have the AP1 intake cam in my F22c,I dont have a before and after plot though(218whp before, 224whp after install)I do remember having gains, now I want the BC stage 2's to compare
Old Oct 23, 2011 | 10:31 AM
s2000maniac's Avatar
whats your rpm redline?
Old Oct 23, 2011 | 02:34 PM
I can take it to 9k but I'm confortable at 8.6k-ish(when I ran nitrous I'd shift at 8k if I could catch it )
Old Oct 23, 2011 | 03:45 PM
soo.....let me get this straight, you can the change the AP2 camshafts with AP1 and safely rev the engine to 9k all the day long?
Old Oct 23, 2011 | 06:40 PM
Members are using AP2 cams and rev to 9k all day long, I think termination is one of those members
Old Oct 23, 2011 | 06:54 PM
Indeed. I rev the stock AP2 F22c to 9k. No AP1 cams... completely stock F22c longblock. Seems to be taking it happily with no problems. Took it to autocross today and it took everything I threw at it.
