Failed to shift smoothly.. a possible damage?
Old Jan 12, 2015 | 07:50 PM
afzan's Avatar
I'm not sure on the exact location but you can see a picture here: https://www.s2ki.com/home/2010/12/02...-transmission/
Old Jan 12, 2015 | 11:01 PM
dlpowered89's Avatar
I am just about to place the order for drain plugs. Do Transmission and Engine share the same plug? I've been searching for the past hour but couldn't get a definitive answer.
Old Jan 13, 2015 | 12:17 AM
Upon further research, it seems like some people are against the idea of having magnetic plugs for these reasons:
1. The magnet itself separates from the bolt. This can potentially cause a lot of issues if it ends up somewhere in the engine / transmission.
2. There is already a built in magnet that takes metal scraps/shards.
I'd like to hear your thoughts on this and possibly get something that works well without breaking. Any thoughts?
Old Jan 13, 2015 | 06:55 AM
Car Analogy's Avatar
Its difficult to imagine the strong magnet becoming separated from its strong attachment to the steel drain bolt.
But I don't see the need to use them. the diff already has one. The trans already has its own magnet, just not on the drain plug. The engine has an oil filter. No metal bits are going to get past it, and oil flows thru it before going anywhere. Yeah, some oil is sloshed around, but IMO its not anything to ever worry about (that you would have metal bits flaking off in the first place is way more of an issue than any damage those particles might cause afterwards.)
Old Jan 13, 2015 | 09:03 AM
CoolGuy094's Avatar
Originally Posted by Utah S2K
Learn something new everyday! I recall checking my drain plug years ago and it was not magnetic. But the Honda 2001 AP1 part database does show a "Magnet,Transmission". Do you know where it lives? Is it up inside?
Great to know. Thank you!
Utah
Its near where the slave cylinder mounts to the outside of the trans, but on the inside (duh, lol).
Edit - yeah that link above shows a good closeup picture of it and you can see it in the picture right above; its on the inner wall at the bottom-right of the picture.
Jeremy Clarkson
Aug 1, 2014 12:01 PM
truekakaka
Jan 20, 2010 04:30 PM
naruto
Nov 15, 2006 02:22 PM
Driv300mph
Sep 4, 2004 05:38 AM
Jason00S2000
Mar 20, 2004 08:55 PM
