Failing Rear Drive Shaft
Old Oct 16, 2004 | 07:02 AM
Gymniac's Avatar
Default Failing Rear Drive Shaft
I was told by my mechanic that I need to replace my rear drive shaft on passenger side.
The sympoms were single "click" from rear-right or rear-center when moving from stop just after lifting off the clutch (1st gear). Or when giving a quick "jab" of throttle at constant load (2nd gear) .
The mech recommands that I replace the entire shaft assembly (upwards of $500) instead of trying to pin-point which component of the assembly and just replacing it.
Is he just being lazy or is it really a sound advise? Anybody have similar experience? Is it usual to have a shaft go like this at 45K ?
Thanks in advance.
Old Oct 16, 2004 | 07:23 AM
Ravenwerk's Avatar
Chances are there's a simple fix for this if this turns out to be your problem. There's a TSB for this issued to the dealerships. Check out this thread (there are many concerning this if you do a search) click here. Hope it's that easy. 5 bills is a stiff penality for retorquing a nut.
Old Oct 18, 2004 | 05:57 AM
Gymniac's Avatar
Thank you so much for the info about the TSB . That sounds very plausible. Made an appointment today...hopefully they won't give me hard time even if I can't reproduce the sound for them.
Buntinboy9
Jun 15, 2011 06:17 AM
WomenBeShoppin
Aug 31, 2009 08:22 AM
s2ke5
Sep 12, 2007 09:32 AM
FASTSIIK
Oct 10, 2005 03:03 PM
