the famous 3rd to 2nd shift
I did the exact same thing 7 months ago. car turned completely sideways, and the biatch turned off. wouldn't turn back on. yes don't pay someone to diagnose anything, it looks like you've taken it apart already.
I paid $2700.00 shipped, for another complete longblock, from another member on this sit. his name is im reebs or im_reebs. you might want to see if he can get you another one. he is very trustworthy, and shipped the motor from TN, to CA, and the motor runs great.
IT was kind of good i blew it, because my motor mounts were all broke, and i had to replace all of them, replaced clutch and flywheel, and did other basic maintenance that would have cost me $$$ down the road, and now i have am otor that has half the milage of my old one...
It did set me back financially, unless you count all the points that it's going to help my credit score for the stupid loan i had to pull out.
Originally Posted by Tjs S2k,Feb 26 2009, 08:42 AM
so no broken valves? You might get away with a head rebuild. How is the block?
I would just give the head a birthday with a set of supertech valves ( $259 from performance closeout on ebay), AP2 or supertech retainers, stem seals. While its apart I would have the valve seats inspected and given a light seat cut if required.
My guess is most of the exhaust valves were touched, and only one got badly bent. I wouldnt trust any of those exhaust valves for future use.
Have a really close look at the cam lobe and rocker on that particular cylinder to make sure there arent any impressions from when the valve got knocked.
You should be able to give the head and parts to a good head reconditioner and they can hand it back ready to bolt on. Make sure they use a Serdi, Mira or other high spec seat cutter. If they mention syncro stone find another shop.
Chris.
Chris.
I too, kind of saw this incident as a good thing, as my engine has high mileage but it turns out that the damage isn't major.
Chris.
Chris.
Originally Posted by Freddy,Feb 26 2009, 07:46 PM
Yeah I already took it apart myself, I'm trying to save money for spring break! hehe or maybe some forced induction on the s.
Originally Posted by JayJones,Feb 28 2009, 02:34 AM
what screwed me over, was that the piston, ended up getting a fingernail size chunk torn out of it, so the block was useless.
I wouldn't write off a whole short block assembly just due to a nick in the piston.
Originally Posted by Freddy,Feb 27 2009, 01:54 PM
Thanks for the information, that's exactly what I needed. Tomorrow I'll be heading to the shop, I'll keep in mind about the spec seat cutters. I'm not too familiar with that but I'll take your knowledge and make it useful. Thanks.
The good machines use a carbide cutting tool that has the target seat shape ground into the cutting edge. It also uses a very accurate method to centre up on the valve guide to keep things concentric.
The latest machines use a computer controller single point cutter to cut any shape seat profile, a bit like a tiny lathe where the tool spins around and the job stands still.
