FEELS 2.3L kit for s2000!!!!!!!
Before you get too excited, a stroker kit like that will most likely reduce the redline, just like Spoon's stroker kit (2.2L) that reduces redline to 8400RPMs - any higher than that you'll risk seeing your pistons make 4 nice holes on your aluminum hood.
Originally posted by liquid215
What kind of gains should we expect with a kit like this?
You don't actually have to bore out the cylinder. You change the length of the rods and diameter of the crank to change the stroke.
I think if the components were say....titanium, you wouldn't have to worry about decreasing the redline.
Blake
Blake
Originally posted by bayarea408
but in order to make the litre go up to 2.2 or 2.3 you have to make the sleeves for the pistons bigger, wont that make the walls thinner and crack the walls during heavy driving conditions?
Originally posted by S2K2GO!!!
It would appear that the increase in displacement comes entirely from increased stroke- no change in the barrels. Resulting increase in piston velocity would certainly reduce redline, so there may not be much HP gain. Mechanical advantage of the crank would increase, so torque could improve significantly. I would not count on optimal induction air or exhaust tuning with this mod, however, so it would be a good idea to see some valid dyno results before diving in. I'll look into gettiong the Japanese translated by a friend of mine who will be visiting.
I believe the S2000 cylinder walls are really thin in relation to each other, so there is not much room to bore them out. Usually when you go for a large increase in size, you do a little of both boring and stroking.
Blake
Blake
