Few Problems
Old May 3, 2010 | 12:26 PM
  #31
CapoArgentino's Avatar
Banned
[QUOTE=hirev,May 3 2010, 12:08 PM] in jan i changed the front pads and rotors myself, it was
easy enough, all i had were the instructions which are here in the sticky area and a exploded photo of where all the parts
Old May 3, 2010 | 12:39 PM
  #32
S2Kmonkee's Avatar
the squeaky sounds you hear is probably the infamous tranny whine. It's very high pitch and lasts for a second or so and it's gone. This happens in mine to.
Old May 3, 2010 | 12:50 PM
  #33
erikvanden's Avatar
[QUOTE=S2Kmonkee,May 3 2010, 12:39 PM] the squeaky sounds you hear is probably the infamous tranny whine.
Old May 3, 2010 | 12:55 PM
  #34
S2Kmonkee's Avatar
you're looking at two people to bleed the brake unless u have a special kit. One person to pump the brake while the other keep track of the fluid and locking the nuts.
for fluid, buy the ATE if you can because it's not the yellowish color but blue so it's makes differentiating the new fluid and old fluid easier.
Old May 3, 2010 | 12:59 PM
  #35
S2Kmonkee's Avatar
oh yeah if you can get a turkey blaster and suck some of the fluid out to get some of the debris out to but remember u don't want to drain it all IIRC.
Btw get slotted rotor just cause they look nice. : D
Old May 3, 2010 | 01:06 PM
  #36
Banned
No need for 2 people or special tools. Just do the gravity bleed. You never need to touch the brake pedal and the results are excellent.
Old May 3, 2010 | 02:04 PM
  #37
erikvanden's Avatar
OK thats what I was thinking. It should be good then. Hopefully I can get this done later this week. I just don't have access to any sort of garage until the end of the week.
Old May 3, 2010 | 02:10 PM
  #38
S2Kmonkee's Avatar
i tried the gravity bleeding method and it didnt work for me. Was taking way to long.
Old May 3, 2010 | 02:28 PM
  #39
Banned
You have to tilt the tubing to a vertical position and let it fill up almost to the top. It fills up pretty quick this way. Then, tilt it down into a container and repeat the process Just be careful when you tilt not to let air go in through were the tip of the tubing connects to the bleed valve and be sure to tilt back up BEFORE you are out of fluid in the tube.
Old May 3, 2010 | 02:37 PM
  #40
erikvanden's Avatar
do you unhook the hose from the caliper then?
