Fireball out of intake manifold
Old Mar 10, 2009 | 04:59 PM
  #21
ans2k's Avatar
well, he took it all apart. he rebuilt the motor. and it was a good working motor before that.
Old Mar 10, 2009 | 05:37 PM
  #22
fadiss2k's Avatar
Its not hard getting to the crank angle sensor. It is on the side of the timing chain cover. All you have to do it get the airbbox out of the way, belt out of the way, the water pump cover thing off(just the wheel with the holes in it), and the 3 bolts that hold the hard water neck on the front of the motor. After that a 10mm bolt that holds the sensor on and just play around with the connector to get it out. Not impossibable by any means!
Old Mar 13, 2009 | 03:10 PM
  #23
fadiss2k's Avatar
Ok, i did a compression check on the motor. It has 150 across all 4. The motor has new rings, bearings, gaskets, etc. So i am figuring since the rings havent sealed yet, then thats why compression is lower at the moment???
Old Mar 13, 2009 | 06:59 PM
  #24
fadiss2k's Avatar
Here is what the cam gears look like with the crank pulley set on the white mark.
Old Mar 16, 2009 | 04:47 PM
  #25
fadiss2k's Avatar
if its not timing, coils, spark plugs, groud or ecu....what else is left?
Old Mar 16, 2009 | 05:07 PM
  #26
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It appears your main sprocket could go a little more clockwise.
This would turn the exhaust cam a little counter-clockwise.
At that point, from your pic, it looks as if the exhaust cam is 1 tooth off.
Old Mar 16, 2009 | 06:33 PM
  #27
Slows2k's Avatar
the cams will move a bit when the cam caps are torqued down.
Old Mar 17, 2009 | 09:27 AM
  #28
fadiss2k's Avatar
Do you align the cams with the TCT on or off? If i take it off i can get the main sprocket to line up right. But when i put the tct on then the main one is always off. i tried moving it forward a link and backwad a link, but it is always off when i set the crank mark to the white one.
Old Mar 17, 2009 | 04:44 PM
  #29
Slows2k's Avatar
The cams are installed after the timing chain is installed, and tensioner is deployed.
Did you install a OEM headgasket or a thicker one?
Old Mar 18, 2009 | 11:42 AM
  #30
fadiss2k's Avatar
oem everything.
ill mess with it some more this weekend and see if i can get it any closer.
