Fireball out of intake manifold
Ok, i have spark, fuel, and compression! If the cams are not aligned, will the car still have spark? Basically what i am trying to figure out now is what does the car disable when the cams are not aligned right?
I put new gas in it and messed with timing some more. I tried to start it again and it was starting for a split second again. But when i opened the throttle a little bit it shot a fireball out of the intake manifold. Any ideas? Could it be firing in the wrong order?
If you got a fireball through the intake manifold, an intake valve was open during ignition. I think your base spark timing is off or your cams aren't lined up right. Opening the throttle advanced it enough to blow back into the manifold.
(advice worth price paid)
Yes, you still get spark with the timing off at any point. You just get it at the wrong time (not at compression) so the car won't run (or it runs like it's on one cylinder).
One more vote for the cam gears being one tooth off somewhere. All the symptoms point to it.
Well its a long shot but you said you were not getting any spark and you were only getting fuel for a while. What can happen is that you were just spraying your plugs with fuel and after you do this the fuel can get into the tiny pores of the porcelain. When it does this fuel is very conductive and it will acutally ground the spark plug out to the cylinder head and casuse you to have no ark at all....
If this is not the case how are your cam sensors they are the guys that tell ecm that #1 is TDC if they were damaged somehow the engine will not start.
Another option is your alternator correctly wired up? This could cause a no start condition.
Is your tps and MAP sensor clips crossed they are the same clips and are inerchangable.
Are your injecter clips in the right order.
Im just trying to give you some possiblities that could cause a no start.
good luck
good luck
