FLEX and EDFC question
Old Apr 2, 2007 | 04:13 PM
r_duff's Avatar
Default FLEX and EDFC question
Does anyone have this problem where the shock body rotates, taking the EDFC motor with it? The only thing that stops it is the wire to the EDFC motor... im afraid this is gonna eventually snap the wires. Is tehre any way to prevent the shock from turning?
Old Apr 2, 2007 | 07:12 PM
r_duff's Avatar
bump!
Old Apr 3, 2007 | 07:03 AM
snakeeater's Avatar
Check Tein's instructions or website FAQs.
There was a review here someone posted about this problem and their fix. Keep seraching
Old Apr 4, 2007 | 08:06 AM
taz5's Avatar
same here, please advice!
Old Apr 4, 2007 | 08:32 AM
apextamer's Avatar
In my installation manual it shows the intallation for an optional kit to avoid this. It seems to be 2 small brackets that mount between the shock and uppermount at there mounting point. This keeps the upper mount from rotating much. When I get home I will see if the manual lists the part number.
Old Apr 4, 2007 | 09:05 AM
Clone's Avatar
I haven't had that happen to mine...
Old Apr 4, 2007 | 06:26 PM
lazykiwi's Avatar
I think u installed it wrong. Cus I just went down and check my edfc. When I changed the settings my motors didn't move and they didn't pull the wires either.
Old Apr 4, 2007 | 06:42 PM
GPS2K01's Avatar
damn-I need to check mine. My fronts were fine. When I installed the rears-I noticed that it just kept turning...damn!!!!going to take my trunk apart now.....
Old Apr 4, 2007 | 07:28 PM
GPS2K01's Avatar
OK-just checked the rears...the EDFC definately keeps turning (although there is good tension on it) I marked the EDFC placement and used the wife to operate the controller-my EDFC motors do not spin at all and I went through the whole range of 16 settings.
I'm definately curious about the solution to your problem.
Old Aug 10, 2007 | 08:34 PM
rainorshine's Avatar
I'm having this issue as well... my front left motor keeps turning until stopped by the wires. It is NOT turning when adjusting the settings, that works fine... the motor appears to turn while driving. Very annoying, anyone have an update on this?
face
Apr 12, 2010 11:39 PM
r_duff
51
Oct 7, 2009 04:22 PM
Trip
Aug 10, 2007 08:46 PM
eeekk
Jul 3, 2007 08:34 PM
revhi
Feb 9, 2005 07:40 AM
