Which flywheel do I have?
Old Jul 5, 2009 | 10:28 PM
Cheese and Onion's Avatar
Default Which flywheel do I have?
I'm running a standard 2004 S2k with the 2 litre AP1 engine (New Zealand spec), it has the CDV fitted and I'd like to remove it.
Will my car be running the heavier AP2 flywheel or is that only on the 2.2 engines?
Old Jul 5, 2009 | 10:52 PM
terahertz's Avatar
my guess is that the "ap2" flywheel only comes with the 2.2. if the heavier flywheel was put on the 2.0 engine, it would make revving slower not to mention the less torque already... but like i said it's just a guess
Old Jul 5, 2009 | 11:12 PM
J0eys2k's Avatar
From what I know the only difference is the exterior, the engine was left untouch(F20C) for New Zealand, etc.
Old Jul 6, 2009 | 12:11 AM
But still with CDV?
Old Jul 6, 2009 | 12:33 AM
terahertz's Avatar
i want to say yes and that i've read it before somewhere... but it's been a while. have you tried searching already?
Old Jul 6, 2009 | 12:34 AM
terahertz's Avatar
actually, i take that back. i'm 99% sure you have it. some late model ap1 in 03 here in the USA actually came with cdv, so i'm guessing your 04 has it for sure.
Old Jul 6, 2009 | 12:50 AM
Thanks guys, and yes, I've searched. I know I've got the CDV (should have phrased my query a little better) as it slips at high RPM shifts, it's not a dodgy clutch, it's CDV for sure.
Really want to remove it but heard some pressure plate/heavy flywheel issues from AP2 owners and wanted to know for sure if I am running the lighter flywheel/CDV combination.
Old Jul 6, 2009 | 01:09 AM
terahertz's Avatar
the only "issues" are that the ap2 flywheel is so heavy it carries so much momentum while spinning. our clutch is not the strongest of clutches, and combined with whatever cdv slipping damage they've already created, they see their clutches still slipping.
Old Jul 6, 2009 | 12:22 PM
Ok, so does anyone know for sure if the AP2/F20C uses the lighter flywheel?
417alex
Jul 11, 2010 09:17 AM
akira2019
Mar 19, 2010 07:17 AM
M2K
Sep 22, 2009 03:39 PM
miamirice
Aug 10, 2009 11:46 PM
