Flywheel removal question
Old Apr 18, 2003 | 04:09 AM
Venomous S's Avatar
Default Flywheel removal question
For those of your that installed a new flywheel, were you able to effortlessly hold it from spinning with some sort of made up tool?
im trying to find out if its a real hassle ill just spend the 100 bucks on the tool
thanks
Old Apr 18, 2003 | 09:43 AM
Squeezer's Avatar
as far as I know, you'll either need get that tool, or get an air impact wrench.
Old Apr 18, 2003 | 11:11 AM
cdelena's Avatar
Although not an ideal technique, you can put a wrench on the front pulley bolt with the handle propped on the cross member to hold the crank still. You would want to crack the bolts loose with a swift impact rather than steady torque, and on install be sure you are exceptionally careful to tighten the bolts very evenly before you torque them down. Having the flywheel tool is preferable, but this will work.
lpcome
Nov 14, 2017 06:17 AM
hambler
Jun 28, 2016 01:35 PM
willyang
Apr 9, 2005 03:44 PM
cdelena
Oct 10, 2002 06:18 AM
