Flywheel shims required?
Old Aug 24, 2016 | 01:05 PM
Charper732's Avatar
Default Flywheel shims required?
I just had my flywheel resurfaced and it needed.045" removed. Shims are available in.025"
Question is, should i go with 2 and be.005 over or go with 1 and be.020 under?
Amazon only has 1 in stock but ill wait for more if i have to. I want to do this right
Old Aug 24, 2016 | 01:21 PM
Mijae007's Avatar
Just had my flywheel resurfaced never even thought to put in shims. Does everybody do this? I was planning on just putting everything in with new oem disk and act pp
Old Aug 24, 2016 | 01:36 PM
windhund116's Avatar
Any issue with ring gear alignment to starter?
Old Aug 24, 2016 | 01:44 PM
Charper732's Avatar
I didn't even think of that, .045" isnt that much though like 1.1mm... I was thinking without the spacer there may be a tad bit less spring pressure from the PP but that was it.
Old Aug 24, 2016 | 07:49 PM
Car Analogy's Avatar
If our cars have a clutch problem, its with sufficient release, not sufficient clamping (for NA engines). A little extra space might be a good thing. I wouldn't do 2 shims for this reason.
Sent from my SM-G920P using IB AutoGroup
Old Aug 24, 2016 | 10:23 PM
Mijae007's Avatar
I hope youre right. I dont think im going to use shims
Old Aug 25, 2016 | 10:47 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
.045 is a massive amount to remove from a flywheel, I find that impossible.
In any case, never shim the flywheel.
Old Aug 25, 2016 | 01:43 PM
Charper732's Avatar
The bolts holding the frictiom had worn into the flywheel, i was able to catch my finger nails on it. I was told.045" came off.
team510
Feb 2, 2015 05:22 PM
andy s2k
Sep 29, 2010 02:17 PM
Alfredo
Jul 21, 2010 09:21 AM
newnan-s2k
Apr 14, 2008 07:28 PM
SteveUCI
Aug 7, 2006 07:20 PM
