Fresh engine
Old Feb 17, 2007 | 11:33 AM
  #21
sahtt's Avatar
The reason for differing 'opinions' here is very, very simple.
This is all you need to know:
S2000's have FRM cylinder walls. This is a very special situation no other motorcycle/car has that I know of off hand.
In NORMAL situations, REGARDLESS of whether it's a CAR, MOTORCYCLE, LAWNMOWER, AVIATION, or GO-Kart engine; the 'breaking in' of the engine/sealing/setting of the rings takes place within 20-50 miles depending on the type of driving you do [I realize 20 miles on lawnmower or 50 miles on a plane is odd but I'm speaking in terms of a normal automobile].
This isn't up for discussion. This is fact. ANY race team that races ANYTHING will tell you this because all combustion engines generally work in the same fashion.
**Yes there are little technicalities with that but no one cares. The rear end, gear box, etc. may also need a break in time as well as other engine components but the bottom line is engines are built to a level of accuracy these days that makes it negligable in 99.99% of cases
HOWEVER, with the s2000's special FRM cylinder walls, you need to stay out of high stress situations [high rpms] to enable THEM to seal/break in/whatever correctly. THEY take longer, 500+ miles.
The only other variables are the type of driving, oil, and how often you change the oil. The last few variables are not very controversial.
Mike9000
Oct 14, 2007 11:49 PM
QUIKAG
Jun 19, 2007 09:06 PM
Jim20B
Feb 5, 2005 07:11 PM
Zanardi50
Apr 27, 2004 04:04 AM
fiv0
Jul 11, 2002 09:35 AM
