Front parking light
Old Aug 12, 2008 | 04:26 PM
JMWulff's Avatar
Default Front parking light
I searched and searched and still cannot find anything on replacing a blown front parking light (behind the amber plastic lens). It looks like you can reach in through a hole in the engine compartment to replace the headlights, but this corner light is too far to reach and get a grip on its holder. I saw one old post that recommended pulling the fender liner, but I'm not sure if the retaining clips/pins will get destroyed when I pull them out. Should I have replacements on hand first? They seem to be putting up a fight with my pulling on them. Did not encounter this problem with the tail light when removing similar clips from the trunk liner to replace a bulb. Finally, is this the same bulb as the tail light (which I have an extra of) or do I have to buy some other bulb? Any help much appreciated.
Old Aug 13, 2008 | 11:12 AM
s2k dre's Avatar
the liner clips wont break, u can reuse them, and just go through the wheel well and its easy!
Old Aug 13, 2008 | 12:58 PM
JMWulff's Avatar
Got it. Thanks!
Old Aug 13, 2008 | 08:10 PM
Burt Reynolds's Avatar
Unless your hands are very large you can easily reach those
Old Aug 14, 2008 | 04:39 PM
JMWulff's Avatar
I can't beleive more people have not posted on this in the past. That's interesting that you can reach the light bulb through the access hole. It seems that the hole was made to replace the headlights AND the parking lights, but I can't reach the parking. Maybe the hole is bigger on ap2s than ap1s. I am fairly large at 6'4" and have large hands, so maybe it's just me. Also, since this is on the right side my arm hits the air filter box as I try to feed my hand through. I will try to see if I can get someone with a smaller arm and hand than mine to try it. The fender liner method suggested by s2k_dre also seems like it will get the job done, just a little bit more work. I was going to try that last night but ran out of time. Thanks, jesse. The LED idea also seems interesting. I'm going to get a bulb to see what that looks like too.
Old Aug 14, 2008 | 06:47 PM
JMWulff's Avatar
Ok, I just saw that you had a CAI in your signature. I bet that is the difference... I just tried again and it seems that there is no way to reach the light socket with the air filter box in the way.
PhreshEmpire
Jun 8, 2012 03:17 PM
DaAznKnight
Apr 12, 2012 06:44 PM
ilaggoodish
Jul 1, 2009 01:17 PM
jah
Sep 26, 2007 12:38 PM
nwlax23
Sep 6, 2006 07:29 PM
