Front wheel bearing replacement
Has anyone replaced front wheel bearings manually with a drift and hammer? Is it do-able?
Or for required forces and access, is it best to use a press?
I've done plenty bearings in the past on the bike with a drift / hammer, but after a bit of searching on replacement on the S, I don't think I've seen anyone mention doing it this way.
Thanks in advance.
Thanks in advance.
While anything is possible I don't think it is feasible to try using a hammer to do this job. Take a look at the threads showing how to do it and locate a local shop to press the bearings. I was disappointed enough in my local options I just bought a press from Harbor Freight for just over $100.
Man we got a 20 ton press at my buddy's shop, and the cool thing is it has a gauge telling you how much pressure is being exerted. The bearings took like 3 tons to press in, and the hub was a little bit less. Compared to pressing in rifle barrels on an AK which take 12-15 tons, pressing in bushings and bearings is cake.
Thank you for that response!
I had someone else in the UK forum state that it took him 4 tonne for his bearing. So, I'm glad to see at least 2 people with fairly consistent force requirements for the job.
heymynameismark
Sep 21, 2015 11:35 AM
snwbrderphat540
Mar 27, 2015 09:50 AM
