fuel feed line removal help
Old Aug 12, 2012 | 08:49 AM
lopez14's Avatar
Default fuel feed line removal help
My main fuel feed line cracked so I'm replacing it with a new one but im having trouble getting it loose from the bottom of the car, there seems to be some white residue. Is that like locktight or something? It is reverse thread or something? That thing is too hard. I'm using a Cheater bar and everything but nothing. Anyone?
Old Aug 12, 2012 | 10:31 AM
MM3Kwolik's Avatar
Make sure you're using a flare nut wrench so you're getting the best bite on the line. You're most likely losing a lot of your torque from an open end wrench/crows foot due to it rounding the fitting slightly. To me, that looks like it might have teflon tape on it to prevent leaks, I could be mistaking though. Get yourself the appropriate wrench and use a little PB blaster and you should be in good shape.
Example of said wrenches:
Old May 22, 2014 | 06:58 AM
Pomo_s2k's Avatar
I'm doing the same job. Did you figure out how to get to the connection under the car and what did do to undo the connection? Thanks
Old Jun 1, 2014 | 07:32 AM
Pomo_s2k's Avatar
Follow up to the above....PB blaster bath the day before and a 11mm flare wrench with some effort it came off. After that, very easy replacing the fuel line. Beware there are slight differences to the fuel rail connection end between myoo-03 and my04-09 fuel lines. Be sure to check the part before installation it's very obvious.
Arslansmc
Mar 22, 2017 12:31 PM
rtboy10
Jul 13, 2015 07:01 PM
rtboy10
Jul 10, 2015 12:16 PM
Orjinal
Jul 12, 2014 02:31 AM
foshdafosh
Feb 27, 2014 07:02 PM
