Fuel Filter Replacement
Old Feb 15, 2021 | 05:27 PM
Slowcrash_101's Avatar
Originally Posted by Live Fast
We already have replacement options for some things & thankfully our cars do share SOME parts.
I do hope we see more people make nicer stuff for our cars. It's to the point where if something happens to my engine, it's cheaper to K24 swap it. If the trans goes well rebuilding it is getting more and more expensive. I hope more development & the Japanese part catalogue pick up more stuff that we can use on the LHD cars.
The S2k transmission is not terribly different than other synchromesh transmissions. It has some neat features that make it very compact, like having the synchro hubs on both input and intermediate shaft. If you take off the bell and tail housing, the actual transmission itself is incredibly compact. There are some delicate aspects to it, and some parts are incredibly tedious, particularly setting the output shaft pre-load, and input shaft thrust. If you're careful and methodical and you have the time, rebuilding a transmission is not some type of black magic. Everything is actually very straightforward. You can get enough parts to slap one together by taking the used transmissions from people you help swap out replacements
The typical culprits are second and third gear, although fourth is also finicky. 1st 5th and 6th typically don't wear out the synchros. These transmissions are expensive to rebuild, not because of parts, but because of the time involved. If you have the time, it will cost you the same to rebuild it as it will to buy a good replacement. ~$1,000 about half of that if you harvest parts.
Slygreen
May 21, 2018 11:02 AM
Midnightdennis
May 6, 2018 02:53 PM
UberDuper
Aug 28, 2015 07:54 AM
rrounds
Jul 23, 2015 06:04 AM
