fuel pressure regulator
Old Mar 4, 2006 | 01:38 PM
Quivers's Avatar
Banned
Default fuel pressure regulator
I am missing the piece for my comptech kit that replaces the stock fpr with the an fitting. until I get that part can I use the stock fpr with my fmu/fpr unit from comptech? also, if I can where would I mount my fuel pressure guage so that I can tweak the pressure.
Old Mar 4, 2006 | 03:25 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
NO.
The pressure will be limited to that of the smaller regulator. You'll lean it out and be sorry.
Old Mar 4, 2006 | 07:12 PM
Quivers's Avatar
Banned
the regulator is on the return side, it wouldnt lean it out. if it was restricting the pressure would stay high.
Old Mar 5, 2006 | 10:48 AM
MB's Avatar
MB
Member
Thats how the Vortech works isnt it?
MB
Old Mar 5, 2006 | 10:52 AM
Race Miata's Avatar
Fuel pressure would be dictated by the higher pressure unit ONLY IF both FPRs are inline (no fuel flow can by-pass the higher pressure one).
Old Mar 5, 2006 | 12:15 PM
Quivers's Avatar
Banned
the vortech fmu doesn't incorporate a regulator in the fmu. the comptech uses an all in one adjustable unit. so the vortech system may or may not use the factory regulator, I'm not sure.
Old Mar 5, 2006 | 01:15 PM
AusS2000's Avatar
If you mount the Comptech downstream of the OEM it would work theoretically (as per the Vortech) but I think it would be as much trouble as sourcing or fabricating a mount for the fuel rail.
Old Mar 5, 2006 | 03:54 PM
Quivers's Avatar
Banned
your probably right, it started snowing now so Im not in a rush to get it rolling anymore.
ego
Apr 8, 2008 01:27 PM
flyboy56
Jan 24, 2008 03:16 PM
oneaudiopro
Feb 23, 2005 01:11 AM
johninator
Jan 31, 2005 07:49 PM
jdmdohcpower
Dec 21, 2004 11:21 AM
