Fuel Pressure Testing
Old Feb 1, 2010 | 08:29 PM
dj-'s Avatar
dj-
Unhappy Fuel Pressure Testing
Am testing fuel pressure on my S. Due to easy access of the rubber return fuel line at the FPR I am using this. Would the fuel pressure be a useable number after the FPR on the return line? I am getting a reading of 12psi which is drastically low and would provide reasoning behing my intermittent stalling and hard starting...
I assume this pressure is lower being down stream in the system... However how much lower would this be..
..Kyle
Old Feb 1, 2010 | 08:51 PM
dj-'s Avatar
dj-
After rereading my post i realize, this isn't a very bright question.. I am going to try testing on the supply line..
Old Feb 1, 2010 | 11:25 PM
spets's Avatar
You want to measure before the FPR, not after.
Old Feb 2, 2010 | 07:39 AM
dj-'s Avatar
dj-
Realising my mistake while thinking about it last night I am now sitting in the office trying to think of an easily accessible fuel supply line prior to the rail. Is there a rubber fuel line that is close?
Anyone have a picture of their bay around that area or a decent diagram?
Old Feb 2, 2010 | 08:01 AM
dammitjim's Avatar
The pump is easy to get at.
Old Feb 2, 2010 | 08:10 AM
rich85tpi's Avatar
Don't most fuel rails have a schraeder valve where you can attach the fuel pressure gauge?
I'll have to check on my S when I get home.
Old Feb 2, 2010 | 08:47 AM
dj-'s Avatar
dj-
The S doesn't have a Shraeder valve..
Old Feb 2, 2010 | 10:07 AM
spets's Avatar
According to the helms, you need to remove the fuel pulsation damper on the fuel rail (looks like a big knob thingy) and attach the pressure gauge there. fuel pressure should be between 47 and 54 psi.
Old Feb 2, 2010 | 12:28 PM
Kermdaddy's Avatar
I drilled a hole on the end of my fuel rail. I tapped 1/4" NPT liquid filled pressure gauge, search for Sidway's install tread.
Old Feb 2, 2010 | 05:21 PM
Slows2k's Avatar
The OEM tool replaces the fuel damper, and a pressure gauge attaches to it.
rtboy10
Sep 1, 2013 04:59 AM
AusS2000
Mar 18, 2008 10:35 PM
synapse
Jun 20, 2005 07:06 AM
