Fuel Pump Install?
Old May 22, 2005 | 05:56 PM
flexer's Avatar
Default Fuel Pump Install?
Hey,
I am looking at putting my new fuel pump in and the factory manual talks about taking off the panel behind the seats....the one that the soft top folds down into. How hard is it to get off? Any pointers you could give me? Any other info from there you could share on this install? THanks
J. R.
Old May 22, 2005 | 06:32 PM
xviper's Avatar
Here is the Vortech installation manual:
http://www.vortechsuperchargers.com/...s/4hs218im.pdf
Go to the page that tells you how to swap the fuel pump. It will give you some hints as to how to get at it. It also tells you to have a Helm service manual on hand if you're going to be dismantling the car in any way. You basically have to remove the fasteners that hold the rear vertical trim on and take that out. Then you unfasten the soft top tray. You have to remove the trunk liner so you can take the tray out via the trunk. Then you work from between the seats from above the fuel tank. Obviously, if you have the windscreen, that must be removed first.
Old May 22, 2005 | 10:08 PM
flexer's Avatar
xviper your like a endless stream of knowledge. What do you do that you get to get on here and help everyone out all day? I want your job!
J. R.
Old May 23, 2005 | 07:19 AM
xviper's Avatar
I got "volunteered".
Old May 23, 2005 | 08:49 PM
SIIK2NR's Avatar
Pump removal is not difficult just a PITA..... here's some good pics of our last pump removal for a SC install for some idea of how it looks.
lg24
Jul 17, 2014 02:52 PM
GDM S2K
Mar 25, 2008 05:34 PM
Dolemike
Jul 6, 2006 11:48 AM
D-S2K
Nov 11, 2005 02:51 PM
lexar13
May 12, 2005 05:52 AM
