Fuel pump not powering up
Old Jun 10, 2007 | 11:34 AM
FF2Skip's Avatar
Default Fuel pump not powering up
First, I do not think there is anything wrong with the ECT mod from Modifry. It is flashing as it should on a cold motor.
I use AEM EMS. After the install of this engine temparature gauge mod, the car will try to start, but there is no audible sign that the fuel pump is working and the fuel pressure at the rail reads nil(have gauge). The car wants to turn over, but is getting zero fuel.
I checked the fuel related fuses- all good. In the process of the install, I unplugged the far right group of wires from the EMS. I also temporarily detached the yellow box for my gears.
So I graciously ask for.... HELP!!! I leave for the track Wednesday.
Old Jun 10, 2007 | 11:55 AM
Envied's Avatar
You might try looking at the fuel injection relays too.. I had an 89 supra turbo that the relay was trashed.
Old Jun 10, 2007 | 12:04 PM
FF2Skip's Avatar
If the fuel pump isn't powering up, I'm not sure how the unjector relay could affect it.
After the normal 2 seconds that the fuel pump would have been noisy(and now isn't), I get a "click" from under the hood.
Old Jun 10, 2007 | 12:06 PM
TheCarGuy2021's Avatar
Very odd... What kind of fuel pump is it?
Old Jun 10, 2007 | 12:53 PM
FF2Skip's Avatar
Walbro 255.
It has to...
I'm an idiot. I reconnected one of the wires as if I were removing the ECT module. Viola! Fuel pump powered up. It was then that I realized that I had cut the GREEN/YELLOW wire instead of the YELLOW/GREEN one!
Old Jun 10, 2007 | 01:09 PM
Stratocaster's Avatar
That was going to be where I had you look. I wanted to say the FP is pin 15 on the 32P connector. I just have not had time to look it up. Glad you figured it out.
Old Jun 10, 2007 | 01:49 PM
gfacter's Avatar
Originally Posted by FF2Skip,Jun 10 2007, 03:53 PM
I'm an idiot.
Old Jun 10, 2007 | 04:33 PM
FF2Skip's Avatar
Thanks, Jeff.
And yes, with George.
Locking.
joefish1298
Mar 30, 2021 12:55 AM
lude9285
May 1, 2016 02:22 AM
Luis06s2k
Forced Induction For Sale
Mar 26, 2011 09:11 PM
Spec_Ops2087
May 18, 2010 01:58 PM
ekoms31
Mar 28, 2010 08:21 PM
