Fuel Smell
Old Jun 29, 2006 | 05:21 AM
S2000_Europe's Avatar
Default Fuel Smell
Hello, a few weeks ago I changed the a modified OEM fuel rail, it had a guage on it, for another OEM fuel rail, used.
Since last week there is a Fuel smell, I checked for any leak but did not found any.
suggestions?
thx
Old Jun 29, 2006 | 08:38 AM
Sideways's Avatar
Since the fuel is clear it is hard to see. Place a piece of colored paper tucked in under the rail and look for the tell tale signs of a leak. Often it is an injector top O-ring leaking. They can get cut or damaged very easily and it is not noticable until you pressurize the system.
Also check around the gauge with some paper for a leak.
Another place where leaks spring is from the dampener not being quite tight enough.
Did you replace the crush washers? Did you make sure to include them?
Old Jun 29, 2006 | 08:58 AM
thanks
THe fuel rail that I have it is 100% OEM the gauge was on the other one
I will check those 3 things that you mentioned
Ruthernerd
Jan 10, 2016 12:29 PM
JuicedS2K
Jul 13, 2010 04:26 PM
2QYK4U
Jun 24, 2007 11:22 AM
ItalianBucwheat
Aug 21, 2002 12:15 PM
infinitebass
Aug 8, 2002 03:06 PM
