Gas Cap Problem?
Old Oct 26, 2004 | 03:27 PM
  #21
mikegarrison's Avatar
Originally Posted by swtazn97,Oct 26 2004, 04:24 PM
I had that gas cap seal problem too. Tri doing this: Instead of tighning the gas cap from the middle grippy thing....Firmly hold the gas cap from the outside ends and tri doing the 3 click thing. it seals alot better that way.
I did that, until that stopped working too. The problem is in the threads of the filler tube, and all 02 S2000s are potentially affected.
Old Oct 26, 2004 | 08:20 PM
  #22
I got the car back. They did the job under warranty. I tried the gas cap and it came off and went back in like a hot knife through butter. So far, so good.
Old Oct 26, 2004 | 08:42 PM
  #23
Ludedude's Avatar
Administrator
Cool
Old Jan 19, 2005 | 08:48 PM
  #24
GrimReaper's Avatar
just a quick note on this: some dealerships will require the CEL for this particular problem to be on in order for them to cover it under warranty. It may not be every dealership, but I know of two here where it was required.
-sam
Old Jan 19, 2005 | 11:00 PM
  #25
CwestinAP1's Avatar
Originally Posted by S2K Mayhem,Oct 5 2004, 02:16 PM
There is a Honda service bulletin, (04-002) which addresses this problem for MY 02 & some MY 03's. Some vehicles came with fuel filler tubes with deformed threads for the gas cap. As a result the cap can click before it's seated, causing the check engine light to come on. The fix is to replace the filler neck.
how do you replace the filler neck?
Old Jan 20, 2005 | 07:49 AM
  #26
I think you go in through the trunk. The TSB probably gives a description of it -- why is that TSB not on this site? In fact, no 04-xxx TSBs are on the s2ki website. What's up with that?
Old Jan 22, 2005 | 11:32 PM
  #27
Optikal's Avatar
I just had this problem happen to me this Friday! Honda is going to cover it because of this TSB, which I never knew about.
dorifito
Mar 9, 2012 08:45 PM
soozookabluS2k
Oct 11, 2011 03:03 PM
paul__chen
Mar 30, 2009 08:56 AM
Amer
Feb 3, 2006 09:29 AM
REVS 9K
Aug 11, 2005 11:38 AM
