Gearbox oil recommendation?
#31
If you like shifts like silk, no matter wich oil you use, give this a try: https://shop.liqui-moly.de/additive/...l-additiv.html
#32
HAH!
Gentlemen, i was completly wrong! Thanks for correcting and enlighting me!
Wonderfull Forum!
But one little thing: I tested the orignal Honda MTF vs. the Ravenol MTF II, i found that the Ravenol works much better. Maybe interesting for European S2000 owners.
Wonderfull Forum!
#33
I bouhgt my S2000 and the transmission was notchy beyond belief. Like a farm vehicle. The 3. gear especially somtimes gives a "blowback" when putting the gear in like firing a 9mm pistol.
ASAP i changed the gearoil to the Ravenol MTF II, that i found much better to the original Honda MTF in my former car, a Honda del Sol.
As expected, this makes things much better, but it was still a little bit notchy.
I go on and added one tube of the Liquy Moly gear additive and this was the finall step so to say, now the shifts are perfectly smooth.
If you think about it, It is crazy to add some MoS² stuff to a gerbaox that relies on friction at the synchro rings for proper function, but it really works.
The "ceratec" additive from Liquy moly should also work, but it´s much more expensiv.
#34
@ ragtophardtop: Thanks. I know that redline makes extremly high quality oils, but they are the most expensive oils you can buy here in germany.
Roughly 30.5 US $ / Quart.
Schaltgetriebeöle Auto - RED LINE Synthetic Öle und Additive
I am not cheap on oil, but.......
but....
maybe i give it a try one day.
I often use the car for very spirited drives cross country and sometimens, not often, beat it over the Autobahn. The S2000 is not build for this, but it´s fun sometimes.
but....
#36
That number is now in the thousands.
Anyone using anything other than Honda MTF to improve shift feel are only masking an underlying problem. It can go 30k miles in a street car, and perform as good as the day it was put in. Track use can surely cut that number more than half.
Im not saying other fluids are worse, and sure there may even be something better.
https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
#38
Did you personally try both Honda mtf and Amsoil mtf? How did you notice or decided the Amsoil lasted longer? And how many kms or miles are we talking about? =)
#39
new fluid feels smooth. over time, the shifting feels more notchy and less smooth.
honda mtf could go almost a year before this feeling.
redline, gm, etc even shorter.
amsoil goes for multiple years and still feels smooth.
i drove about 15,000 miles per year when trying these various fluids.
#40
My experience is that the Amsoil makes for a more notchy feeling at cold startup than the Honda MTF, but ends up super silky smooth once warmed (which doesn't take long).
EDIT: This is on Amsoil MTF that's <1 year old.
