Gearbox query
Old Dec 8, 2002 | 04:24 AM
Johns999's Avatar
Default Gearbox query
I recently testdrove a 2001 car (16000 miles on the clock) , and I noticed a slight issue, just wanted to know whether it was normal or not.
On the whole the gearbox seemed fine, apart from when going from 2nd to 3rd it seems to 'catch' slightly. It doesent crunch or grind at all , its just not as smooth as going into any of the other gears. The car was cold and I only did a few miles,so I was wondering whether its something that they all do, or whether it goes away once its all warmed up.
Old Dec 8, 2002 | 04:29 AM
dlq04's Avatar
The short answer is Yes, this is quite common.
The longer answer (probably more than you wanted to know) is as follows:
SHIFTING
A large number of owners have reported either a notchy feeling or actual grinding when shifting in the lower gears since the car was introduced. Others report it is the smoothest shifter ever.
Soon after it
Old Dec 8, 2002 | 04:40 AM
Johns999's Avatar
Thanks for the excellent quick response, so basically its pretty normal and does not indicate that there is a specific problem with this particular car.
I think I'll buy it then, I was just a bit worried that after reading numerous threads on here about busted boxes, that this car had a box that was on the way out.
Old Dec 8, 2002 | 05:18 AM
dlq04's Avatar
Sogno
Sep 16, 2008 08:48 AM
jal3lee
Nov 25, 2005 09:11 AM
S2000 0E
Feb 19, 2004 01:22 AM
steve_the_greek
Apr 26, 2002 06:17 AM
SLD2000
Feb 13, 2002 10:06 AM
