a good / strong solution to remove...
Old Apr 5, 2007 | 03:46 PM
RunUrAss's Avatar
Default a good / strong solution to remove...
while i was trying to paint the shift patterns/numbers i accidentally started to rub away at the film that's on top of the shiftknob..now it look liks kaka unless i can rub the whole thing off..problem is rubbing alcohol alone (which i used for the booboo's i made while doing the painting) isnt strong enough to completely take off all the film...i also dont want to ruin the actually shiftknob by using something too strong...can anyone recommend me a good/strong solution to get this clear film off the shiftknob?
TIA
Old Apr 5, 2007 | 04:43 PM
RunUrAss's Avatar
bump
Old Apr 5, 2007 | 05:23 PM
RunUrAss's Avatar
bump x2 =(
Old Apr 5, 2007 | 05:42 PM
crackaonrice's Avatar
Uhhhhhh...i don't know if it will ruin the rest of the shift knob...but if you get something like Trichloroethylene (TCE) or some other organic solvent, you should be able to get it off.
gasoline might also work.
might want to test on some indiscriminate area first
Old Apr 5, 2007 | 05:55 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'd spin it in a drill press with fine sand paper.
Give it to me next meet and I'll make it pretty
Old Apr 5, 2007 | 05:56 PM
SenderGreen's Avatar
maybe oven cleaner? It'll eat anodizing. If it's anodized find something else.
Old Apr 5, 2007 | 05:58 PM
RunUrAss's Avatar
hey bill i gave you a call today..did you get my message?
Old Apr 5, 2007 | 05:59 PM
Billman250's Avatar
Top Answer: 1
Yup....got it too late.
Old Apr 5, 2007 | 06:00 PM
RunUrAss's Avatar
it's cool..chad and i worked it out...i'll let you see at the next meet
