GOOD Vibrations
Old Sep 12, 2007 | 08:47 AM
AslanS2K's Avatar
Arrow GOOD Vibrations
when i get above 60 mph, theres a vibration whenever i hit the gas. let go of it and the car is butter smooth so im assuming it isnt tire balance or brake rotors? what else could it be. The car is a2001 with just under 26 K on it. Lemme know what you all think
thanks in advance.
NEW INFO: no when hit the throttle the car goes right a little when I let off it goes left (or the other way around, but regardless it shifts with the throttle). Also, when i shift, the car cocks sideways a little if i let off the clutch abruptly, but not too bad, not dumping the clutch or anything.
Im having the CV cups checked on friday under the TSB. hopefully that fixes it.
Old Sep 12, 2007 | 11:49 AM
negcamber's Avatar
Is your car lowered?
BTW...use Honda MTL for the tranny. LE is ok for the diff though.
Old Sep 12, 2007 | 05:39 PM
AslanS2K's Avatar
yeah its lowered, but it didnt do it before
Old Sep 12, 2007 | 08:09 PM
ESCALVANTE's Avatar
Unhappy
Check out this thread I made about a very similar problem I had:
Wheel Bearing Help...
GL with this issue.
Old Sep 13, 2007 | 06:51 AM
negcamber's Avatar
The vibration you describe is common on any S2k which was lowered after it has some miles on the car.
There are a couple of fixes. One is free if you can do the work yourself...swap the inner CV buckets from driver's side to passenger side and vis versa. Or you can buy and install driveshaft spacers.
Search for a LONG thread in Under the Hood on "spacers" and you can learn what is happening.
Old Sep 14, 2007 | 11:35 AM
AslanS2K's Avatar
cool thanks. im gonna look into that TSB on the CV cups
Lord09
Mar 25, 2014 10:53 AM
donaldmejr
Nov 13, 2011 08:08 PM
megathunder
Mar 14, 2009 03:15 PM
agentRak
Mar 4, 2009 03:11 PM
Sparta
May 23, 2004 03:49 PM
