A good workout driving my S
Recently i've noticed my car likes to swerve/shake subtley left to right and it's taking increasing more muscle to move the wheel. Do I need a full balance & alignment? Thanks.
Yes, start with tire pressure. Then, if you still get a slight oscillation in the steering wheel, check for any missing wheel weights and look into the balance. Usually, you can concentrate on the front wheels as the rears won't be easily noticed if they are unbalanced.
If you get a pull to one side of the other with all your tire pressures correct, then look at alignment.
I think 25 psi would make for a bit heavy steering and cause the car to act like a "wandering gypsy".
Oh, and bring those rears down a few lbs. too. And check and set your tire pressures when cold (like after it has sat overnight).
Originally posted by LordMagnet
dave, i set them to 32psi all around does that sound alright?
