Got *MORE* Boost? Vortech high boost pulley installed...
Old Oct 24, 2002 | 04:30 AM
Yellow Streak's Avatar
Originally posted by cjb80
PS-Yellow Streak, I am using 720cc injectors and the car idles great, and has good throttle response.
That is very interesting that it works for your car. I was under the impression that Randy couldn't get his car lean enough with larger injectors (even with V-AFC tuning). Is the difference in FMUs? What else could it be? Randy - can you add some more to this conversation about injectors and A/F ratio?
-YS
Old Oct 24, 2002 | 04:54 AM
cjb80's Avatar
I am using a stand alone with a 1:1 fuel pressure regulator, that's the main difference..
Chris
Jenner's Avatar
Great job Mikey! Now just check out that air/fuel and get some dyno numbers.
Any chance you have the new belt part # and/or size for me? Also how much fuel are you adding with your VAFC? +10? +20?
Old Oct 24, 2002 | 05:57 AM
S2K's Avatar
S2K
m777erlin: I don't recall, but have you done any internal work on your motor? Can't wait to see what you put out on that new setup!!!
Old Oct 24, 2002 | 06:15 AM
m777erlin's Avatar
I have the model number for the belt at home, I'll send it to you and Vortech later tonight. I added enough fuel until my A/F was 12.6-12.9 during high boost which didn't max out my VAFC so I still have more room to go. I am curious on how the ECU will handle the VAFC being maxed but I won't try anything else until I hit the dyno. I will also pull the plugs later on today to check for detonation and other issues, but so far so good!!!
Old Oct 24, 2002 | 06:17 AM
m777erlin's Avatar
[QUOTE]Originally posted by S2K
[B]m777erlin: I don't recall, but have you done any internal work on your motor?
Old Oct 24, 2002 | 06:25 AM
[QUOTE]Originally posted by m777erlin
[B]
Old Oct 24, 2002 | 08:04 AM
evo s2000's Avatar
Happy BOOOOstinggg
Old Oct 24, 2002 | 01:03 PM
1Randyc's Avatar
Wow, nice job!
I would love to see the dyno as well as ride on it
I hope you pull some really good numbers!
CongraT!!
Old Oct 24, 2002 | 01:17 PM
m777erlin's Avatar
Going dyno right now. Wish me luck guys!
Mike
