Grind at revving
Old Aug 23, 2015 | 01:54 AM
Minossos's Avatar
Default Grind at revving
Hi guys,
I haven't found a solution so i startet up a new one.
I bought an S 2000 3 Weeks ago and this noise is mocking me.
I found this vid that sums it up pretty nice.
https://www.youtube.com/watch?v=6uqvXGF8-pM
When u skip to 03:10 when he starts revving the engine this cyclic *ch ch ch* at start and when the engine decelerates again.
U can also hear it nice at 04:28 when he releases the throttle from the back this time though.
Noise is only at the start or when releasing, if u hold the throttle it disappears and sounds normal. (just like in the vid)
It's also sometimes after start up especially when the engine is cold 1-2 seks but never comes back at idle once the engine is running.
Friend of mine said propably the belt tensioner.
Any suggestions?
It's a 2007 with 30k miles on it.
Old Aug 24, 2015 | 05:26 PM
Car Analogy's Avatar
Very easy to diagnose the belt tensioner. Just remove the belt, and see if noise still there.
Don't run it this way for more than a min or two, as no coolant will be circulating.
You don't have to fully remove belt. Just undue the tension and slide it off tensioner pully.
In this state you can also spin the tensioner pully, see if it spims smooth and noise free.
I'm 5 min you can rule out or confirm tensioner.
Old Aug 25, 2015 | 01:13 AM
jkelley's Avatar
But be sure it's far away from the crank pulley of course, if you're running the motor this way
Old Aug 25, 2015 | 09:34 AM
Minossos's Avatar
Thx for your answers, i will try it this way
Couldn't imagine what it otherwise should be.
Can2ski
Sep 28, 2016 09:54 PM
Spec_Ops2087
Jun 21, 2013 08:23 PM
lower
Dec 12, 2007 01:50 AM
Empedocles99
May 23, 2005 12:56 PM
BigMeanBull
Jan 25, 2005 02:39 PM
