Grinding from first to second.
The syncro on the s2000 is pretty weak. There are 3 inner teeth that end up chipping making it impossible to shift into second at high rpm without first going into another gear. The grinding will not always occur until all 3 inner teeth are chipped. To test the condition of your 2nd gear syncro, just rev up to 9k and go into second. Do the shift slowly, but don
you are not supposed to skip gears that is even more damaging for the sychros. As far as the 1-2 grind woodward had a thread here where he described how the 1-2 shift has the biggest difference in rpms than any other shift and the sychros can just not keep up with the quick shift that the wonderful s2k gearbox is capable of. I found that only when Im really pushing the car I will grind second but any other gear i shift as fast as possible without a single grind. Just give it a little before you slam it into second and you will be fine. Redline MT-90 works awesome for me.
Originally Posted by elemental79,Nov 16 2004, 02:49 PM
Hey, does anyone know if you were to change your final drive gear to 4.77 would the change in rpm difference help keep the synchro from chipping? I just know im going to have to replace it again one day, Its impossible for me not to grind 2nd gear every now and then.
yes skipping gear is detrimental to the gear box especially from say 3 or 4 to 6th. I shift just a little slower going into second but do not seem to fall out of vtec. I thought though however that 1-2 puts you at 5900 rpms but i could be wrong
