grinding going into third
Old Apr 20, 2005 | 08:55 AM
phillys2k's Avatar
Default grinding going into third
driving into first and second but when i hit 3rd 3 out of 5 times feels like something is blocking 3rd i can get it in but feels like a little force i have to put in. i only have 7 thousand miles on my 0-1 can someone help me out?
Old Apr 20, 2005 | 09:49 AM
phillys2k's Avatar
can i get some help anyone?
Old Apr 20, 2005 | 10:50 AM
xviper's Avatar
Can I assume you "cut the corner" when doing the 2 - 3 shift? That is to say, the direction the stick takes is NOT a diagonal, slanted line. You must go up, then to the right, then up. If you cut the corner, you may get away with it for a little while, then you wear something down and it catches up with you. Eventually, by cutting the corner, you'll snag another shift piece and that's what you feel. Now, you may have to always do the "3 step" shift from 2 to 3.
ps. Have you ever had the clutch fluid flushed and changed in all the time you've had the car? It might be time. This "might" help the alleviate the problem a bit.
Old Apr 20, 2005 | 11:04 AM
foolio's Avatar
Try GM Synchromesh FM fluid. It eliminated my 2nd->3rd notch, if only for 2000 miles.
TheBigS
Jan 1, 2015 08:52 AM
XxMerlinxX
Oct 7, 2013 02:07 PM
mh6558
May 12, 2013 09:09 PM
GregFarz78
Oct 19, 2009 04:15 PM
erikmoeser
Nov 13, 2006 02:27 PM
