Grinding Noise
Hello, need of help. I have a 2003 dropped on ksports. I recently been having a grinding noise coming from the rear passenger side. I took the wheel off and checked the rotor and breaks and they all seem fine. I talked to my local Honda dealership and they couldn't figure it out. so i check online and someone said it could be something to do with my rear hub and rust. so i went and cleaned it out and regressed the axle and hub. put it back together and its still making the noise. I noticed in reverse it doesn't make any noise only when i go forward and at any speeds. It almost sounds like the grind happens every rotation. So if anyone ever had this problem could give their input would be awesome or knows hows to fix it. It would be super helpful.
also if it matters me and my friend had it up in the air and ran it and it didn't make any noise. It seems like it needs the weight of the car to do it.
might be the wheel bearing. mine was making a constant grinding/scraping noise that was alot louder over 50mph.
when I popped the axle out, and turned the hub by hand, it was all notchy and didnt spin smooth.
replaced and noise gone!
