Guage cluster is flickering.... :(
Old May 16, 2006 | 06:23 PM
Incubus's Avatar
Originally Posted by SS2000GT,May 12 2006, 10:36 PM
i don't think that you can return battery's man
A battery's what? What is a battery's man? He was talking about returning batteries.
Old May 17, 2006 | 08:35 AM
Squeezer's Avatar
voltage regulator on the alternator is failing
Old May 17, 2006 | 08:59 AM
littlerocket777's Avatar
Try the multimeter test. 10-12 volts measured from the battery when car is off. 13-15 volts measured from the battery when car is started. Whichever is off is the problem. Usually this solves it.
Old May 17, 2006 | 12:22 PM
CIVICTOS2000's Avatar
take the battery off while the car is running....if the car goes off is the alternator if not is the battery.....but it sounds like a alternator poblem....
D.
Old May 17, 2006 | 05:53 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Don't change parts. Put a meter on it while it's running and see if it's charging.
12.6 volts means you're not charging. 13+ you're good.
Take a look at your main fuses as well.
Old May 17, 2006 | 05:56 PM
Billman250's Avatar
Top Answer: 1
Whatever you do, DON'T do this.
If you don't need an alt, you might after doing this.
Old May 17, 2006 | 06:42 PM
Slows2k's Avatar
This Full fields the alternator, with a battery in the circuit to act as a voltage stabilizer. Not a good idea.
Old Aug 27, 2012 | 02:23 PM
4wheelsoffury's Avatar
Bump from the dead. My '02 is doing this, i'll check it tomorrow and post up what readings I get.
Old Aug 27, 2012 | 09:16 PM
silvermonster's Avatar
try replacing your alternator rectifier...i just did my tonight. Its not bad and the part is only 190-220 depending on where you get it. Pretty simple, remove alternator and unbolt the screw on the back of the alternator. The rectifier is the 2nd thing that comes out.
will see if it fixes the problem tomorrow when I drive the car but i'm sure it will fix it.
better than spending 1k on replacing the alternator.
Old Aug 28, 2012 | 02:11 PM
Yeah I assume it has something to do with the alternator/regulator or ELD in the fuse box. I checked the charging volts and its about 14.3 without load and 13.7 with the fan on high and a/c on so traditionally its okay. I did cca test the battery which failed with a bad cell, so I ran to honda and replaced it which left me with nothing changed except a new battery lol. Oh well, i'll just wait and see what comes, it only flickers with the fan on high and/or ac on anyway.
