Guage cluster is flickering.... :(
Old Aug 28, 2012 | 02:58 PM
  #21
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Flickering dash = bad rectifier.
Disconnecting the battery with the engine running is the best way to fry it.
Jump starting can also ruin the rectifier. Not the act of jump starting itself, but letting the alt charge a dead battery.
"Mechanics" disconnect batteries to test alternators. Technicians break out the voltmeter. Be the later.
Live and learn
Old Oct 20, 2012 | 02:49 PM
  #22
sata3000's Avatar
How do you find this part? Used alternator or buy it new from Honda?
Sent from my Galaxy S II using Tapatalk
Old Oct 20, 2012 | 03:11 PM
  #23
Billman250's Avatar
Top Answer: 1
New from Honda.
Old Oct 21, 2012 | 06:35 AM
  #24
sata3000's Avatar
Is this what i need? http://www.hondapartsunlimited.com/o.../31127-pcx-j01
Old Oct 21, 2012 | 12:11 PM
  #25
Croc's Avatar
in my case they eventually overhauled the rectifier and it solved the problem.
https://www.s2ki.com/s2000/topic/799...trument-panel/
2 years and still OK
Old Oct 22, 2012 | 02:34 AM
  #26
ScottyS2k's Avatar
Yes that's the right part. I replaced mine a few months ago, very straight forward job. Once I got my old one out I tested the diodes with a multi-meter, half of them didn't pass the ops check in the FSM! New rectifier completely solved the flickering at idle. My dash never flickered until last year when I took my first trip out to tail of the dragon. After a hard run I noticed the flickering, so I don't know if it's heat related or from continuous high RPM or just a coincidence, but after installing the new rectifier I have since been back to tail of the dragon and I still have no flickering, and this trip was hotter and I drove harder so hopefully that means it's fixed for good and wont be a recurring issue.
staylor725
Dec 4, 2015 06:46 AM
godzilla_753
Jul 30, 2010 07:53 AM
Hero
Mar 20, 2009 10:41 AM
kaissi
Feb 16, 2009 02:18 PM
