guess who blew a differential for the second time??
Old May 7, 2002 | 08:31 PM
  #21
RT's Avatar
RT
Originally posted by The Unabageler
the axle was hanging freely in the inner CV boot, so gonna replace LI CV joint and the axle assy.
WOW, did it mangle the CV boot or just spin inside it? That tripod deal that's on the splines of the axle must have cracked
Old May 8, 2002 | 07:23 AM
  #22
The Reverend's Avatar
Hey RT, what's up with those driveshaftshop CV's??? Are they working ok? What will the $damage be for us commoners?
Old May 8, 2002 | 08:35 AM
  #23
RT's Avatar
RT
[QUOTE]Originally posted by The Reverend
[B]Hey RT, what's up with those driveshaftshop CV's???
Old May 8, 2002 | 09:35 AM
  #24
The Unabageler's Avatar
[QUOTE]Originally posted by RT
[B]
Old May 8, 2002 | 09:40 AM
  #25
[B]
Rev, they charged me just short of 300 bones for the one, and I supplied the core
Old May 8, 2002 | 12:40 PM
  #26
RicePimp's Avatar
that's exactly what they said...the splines broke so they want to replace the whole axle/CV joint assy.
How exactly where the splines broken? I had a very similar problem with a remanufactured joint (on a different car) where the CV joint would just spin and grind when putting the car in drive (auto). I took the joint out and it was obviously the inboard CV joint since the boot was twisted around itself but the joint seemed to work and feel fine off the car. Only by really torquing the joint would it slip. Since I bought a complete remanufactured axle I just exchanged it and put a different one on, so I never got a chance to pull the boot to figure out what exactly caused it, but it was really strange. It sounds exactly like what you describe and I was really wondering how the heck the joint could feel so solid and smooth off the car but sound like it had completely exploded when it slipped on the car. When you really turned hard on the housing it would finally give and slip into the next "groove". Sort of like a stripped bolt or something. Sound similar?
Old May 8, 2002 | 01:35 PM
  #27
RT's Avatar
RT
My guess is the base ring of the tripod cracked (at the root of a finger) and only opens when a large enough torque load is applied.
Old May 8, 2002 | 02:33 PM
  #28
i'm telling them to give me the old parts, then i can open it up and see the exact failure...right now u just see the shaft hanging loose inside the boot.
Old May 8, 2002 | 03:52 PM
  #29
RicePimp's Avatar
That sounds a lot more catastrophic than what happened to me. Sounds like the shaft pulled out or broke. I'm surprised it even turned when you had it up to test the operation, maybe the small torque from turning by hand was being transmitted through just the boot to the housing. Too much torque and the boot just slips where it's clamped to the axle or housing. At least it's not the diff. Should save mucho $$$.
Jason00S2000
Feb 12, 2004 01:50 PM
BrandonS
Apr 11, 2003 08:18 PM
espentan
Oct 30, 2001 11:47 AM
SS2k
Sep 11, 2001 12:34 AM
RT
Jun 21, 2001 07:39 PM
