Half shaft spacers.
Originally Posted by SpitfireS,Nov 14 2007, 11:53 AM
The same would have happened if you would have:
#1 - swapped the CV buckets left/right (and its free, just tools and knowledge needed)
#2 - used new buckets (thats expensive)
The spacers may seem like a cheap cure, but you are also creating a weaker mechanical axle setup.
You need longer bolts to bolt it all together = weaker.
The CV bucket isn't directly clamped on the output shaft anymore = weaker.
When are you going to do an animation of the movement with DynaGeo?
If you export the animation as an html fill I'll host it for you.
[QUOTE=matthouston23,Nov 14 2007, 12:01 PM]I'm thinking it's the rear wheel bearings, because I swear it's coming from something at the wheel.
And, yes, my wheels/tires are balanced, etc, etc, etc.
RED MX5 Posted on Dec 11 2007, 01:49 AM
I've been kinda busy doin' this:
https://www.s2ki.com/forums/index.php?showtopic=549175
Not nice to see what I'm in for when it's my turn.Glad to see that you finally got the bolts out. How's it going now that you're over that hurdle?
I just spent the last 2.5 hours reading through the entire thread. Very informative I might add. I'm still trying to digest some of the terms/concepts as it's not really clear for me at the moment, but the diagrams definitely helped. I didn't see a definitive answer from Billman regarding the measurement of the suspension, is that still going to happen?
Thanks
Eric
Thanks
Eric
Yes but still none the less, many people that had a vibration, have bought the spacers and thus have solved it. So they are useful no matter how or how not useful you may say or think they are.
If your fine without them great, if you run them great!
