Hardtopguy Clutch Kit...
Hey guys, i'm in the middle of changing out my clutch and I just realized that the Hardtopguy clutch kit that I have doesn't have any hardware with it. Is the clutch kit suppose to come with it or do I reuse the stock bolts? I know that I will need a flywheel to crank, and a flywheel to pressure plate bolts. Thanks.
the kit i got only came with the PP,FD,FW,TB(throwout bearing) and that's it. i had it installed by someone else so i can only assume they reused everything else. I wasn't charged for any additional parts so that's where my assumption comes from.
I just had mine replaced this last week and you reuse all the bolts. The propshaft bolts are the ones you might have a problem with...make sure you have a set handy just in case you have to drill them out.
I did mine, and reused all the bolts as well as the big washer/spacer for the flywheel.
