Harness....
Old Dec 16, 2008 | 05:03 PM
fokissed's Avatar
Default Harness....
Got a 07 with no motor or tranny.
I am looking at putting a AP2 motor in it with a AP1 ECU.
Will the Interior Harness plug in to the ECU.
Old Dec 16, 2008 | 07:41 PM
negcamber's Avatar
I don't believe that will work. There are harness differences. One I can think of right off the bat is the air pump. The DBW cars don't have one. The ap1 ECU is designed for a wiring harness with a sensor for the air pump...you get a CEL if you remove the air pump from an MY00-05 car.
Old Dec 17, 2008 | 12:11 AM
Jdmhouse's Avatar
Wouldnt even matter. The AP2"b" 06+ is 4 plugs on the ecu and the AP1 and AP2"A" 04-05 have only 3 plugs. All of the wiring is different on the "B" and it uses CAN which the AP1 and AP2"A" dont use. Besides I wouldnt run a 2.2L with a 2.0L ecu anyway. Unless you gut the 07 and put ALL 00-05 wiring guts in it...there is really not a way around you just needing a 06+ swap and ecu because of the major differences.
Old Dec 17, 2008 | 02:27 AM
s2k_ed's Avatar
well that and what about throttle by wire? i dont think its going to work considering all ap1's are cable...
Old Dec 17, 2008 | 05:51 PM
fokissed's Avatar
Oh so pretty much If I have a AP2 I need to use AP2 ecu? I like having the 9k rev limiter on my AP1 so I wanted to make my AP2 like that but still have the torque from a AP2 motor o well thanks for the help.
OneSilverS2k
Mar 17, 2011 10:35 AM
9krevvin
Feb 15, 2011 08:20 PM
drhess06259
Dec 6, 2009 02:30 PM
s2ksang
Feb 26, 2009 09:45 AM
wazzurp
Sep 20, 2006 06:05 PM
