Having to force 1st, 2nd, & Reverse Gears? Help...
Old Apr 28, 2005 | 10:07 AM
stryder9's Avatar
Thumbs up Having to force 1st, 2nd, & Reverse Gears? Help...
I don't exactly know what this could be, but I'm having these symptoms. When starting my car for the day, it's difficult to get into 1st, 2nd, & Rev Gears. The car also boggs a bit from a dead stop. I usually have to get the rpm's up to get it going without stalling it. Gears above 2nd are fine. I don't feel any slippage or anything. As far as I know the clutch isn't abnormally sloppy. So what gives? Where do I begin troubleshooting this problem. Is it my clutch? fluid? tranny? or syncros? I'm at a lost here, but would appriciate some insight from some of you pros on this board. Thanks in advance guys. BTW, I did the tranny fluid about 3 weeks ago to with AC Delco Syncromesh. I had this issue before that, but I thought it could only help to have fresh fluid in there...Details : MY00 and I don't believe I ever got the decel buzzing TSB ever done...
-Vu-
Old May 2, 2005 | 05:07 AM
stryder9's Avatar
I think I figured it out... It's got a lot to do with a cold tranny & a map sensor that needed some whacking..BTW for those that have the same problems with the map sensor there's an updated part out that you can get to avoid having to whack the darn thing anymore.
-Vu-
Old May 2, 2005 | 08:50 AM
apex2k's Avatar
Friction Modified??
Old May 2, 2005 | 07:02 PM
stryder9's Avatar
Yes, Friction Modified...88900333 Synchromesh Transmission Fluid from hardtopguy.com. Great site, it even recommends the neccesary washers for the job. I get a lot of stuff from him. He's also got the updated map sensor kit & tie wrap for a lot less than the dealer.
Old May 2, 2005 | 08:23 PM
Slows2k's Avatar
Moving to UTH
Old May 3, 2005 | 05:04 PM
Project SSAP1's Avatar
cold tranny does it all the time....forget about it during the winter months...dont think u can get around it even with fresh new fluid
s2k_mh
Dec 13, 2009 05:10 PM
SI JASON
Jul 30, 2009 10:12 PM
cvedral
Nov 6, 2008 02:23 AM
00blackap1
Sep 30, 2008 04:13 AM
BowlofRice
Apr 10, 2007 05:41 PM
