Head gasket removal head etc
Old Nov 14, 2017 | 09:17 AM
SideWaysOnFire's Avatar
Default Head gasket removal head etc
Hi guys anybody done a replacement head gasket please point me to the right place to watch a few tips cheers
Old Nov 14, 2017 | 12:58 PM
jyeung528's Avatar
service manual.
you can google s2000 service manual pdf download
don't resurface the head. follow head bolt pattern when removing and torquing head bolts. although not required, i recommend using new head bolts.
Old Nov 14, 2017 | 10:34 PM
starchland's Avatar
Why recommend using new head bolts? Manual says measure and see
Old Nov 15, 2017 | 09:08 AM
jyeung528's Avatar
to avoid any headaches related to mis-measurements.
Old Nov 21, 2017 | 07:16 AM
Any idea how much they can skim of the head to make it flat?
Old Nov 21, 2017 | 07:44 AM
starchland's Avatar
Please google s2000 service manual. It will tell you everything you need to know. You don't want to touch the head unless it needs it from what I have read
Old Nov 21, 2017 | 08:35 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Service manual is incorrect for two specific reasons.
The head is best pulled by leaving the intake manifold, hoses, and wiring all in place.
The current mill spec is void due to the current ongoing loose chain/TCT noise syndrome. ANY amount taken off the cylinder head will skew the chain geometry beyond acceptable limit. It will cause the chain to hook over the top side of the passenger side moveable chain guide, forever accelerating the chain wear, and tensioner problems.
Unless your engine was severely overheated, or the HG is currently leaking, there is no milling required.
I have over two dozen head jobs to date, none were milled.
Old Nov 28, 2017 | 11:27 AM
shogunmma's Avatar
My previous owner had the head gasket replaced. If I need to check the head to see if needs to be skimmed, do I need to take the intake manifold off in order to test it? I'm assuming the only way to test is to flip the head over.
Old Nov 28, 2017 | 04:36 PM
windhund116's Avatar
Yeah. Use a straight edge and feeler gauge:
DhaughnS2K
Feb 16, 2019 05:42 AM
Lair
Sep 10, 2017 05:03 AM
Brndon
Aug 2, 2013 04:50 AM
vert2k
Mar 26, 2012 03:16 PM
BoostNhigh
Jul 10, 2009 05:18 AM
